description
Configures a description for this WLAN
Syntax
description <LINE>
Parameters
description <LINE>
<LINE> Specify a description for this WLAN
The WLAN‘s description should help differentiate it from others with similar configurations. The description should not exceed 64 characters.
nx9500-6C8809(config-wlan-test)#description TestWLAN
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 uthentication-type eap
 accounting syslog host 172.16.10.4 port 2
 data-rates 2.4GHz gn
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 broadcast-dhcp validate-offer
Related Commands
no (wlan-config-mode) Removes the WLAN‘s configured description
