root (meshpoint-config)
Configures this meshpoint as the root meshpoint. Root meshpoints are generally tied to an Ethernet backhaul for wired connectivity. By default this option is disabled.
Syntax
root
Parameters
None
There are two ways of configuring root access points within a meshpoint.
  1. First method:
    • Configure two meshpoints, having the same meshid, one with the root option enabled and the other configured as no root
    • Apply the root meshpoint to the root access point and the no-root meshpoint to the non-root access points.
    The following examples show the configuration of a meshpoint for the root access point:
    nx9500-6C8809(config)#meshpoint root
    nx9500-6C8809(config-meshpoint-root)#
    nx9500-6C8809(config-meshpoint-root)#meshid test
    nx9500-6C8809(config-meshpoint-root)#root
    nx9500-6C8809(config-meshpoint-root)#security-mode eap
    nx9500-6C8809(config-meshpoint-root)#commit
    nx9500-6C8809(config-meshpoint-root)#show context
    meshpoint root
     meshid test
     beacon-format mesh-point
     control-vlan 1
     security-mode eap
     root
    The following examples show the configuration of a meshpoint for non-root access points:
    nx9500-6C8809(config)#meshpoint no-root
    nx9500-6C8809(config-meshpoint-no-root)#
    nx9500-6C8809(config-meshpoint-no-root)#meshid test
    nx9500-6C8809(config-meshpoint-no-root)#security-mode eap
    nx9500-6C8809(config-meshpoint-no-root)#show context
    meshpoint no-root
     meshid test
     control-vlan 1
     security-mode eap
     no root
  2. Second method:
    • Configure a no-root meshpoint and apply to all access points in the meshpoint.
    • Log into the meshpoint-device > no-root configuration mode of the root access point and enable root.
      meshpoint no-root
       meshid test
       control-vlan 1
       security-mode eap
       no root
      nx9500-6C8809(config)#ap81xx B4-C7-99-71-17-28
      nx9500-6C8809(config-device-B4-C7-99-71-17-28)#meshpoint-device no-root
      nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#
      nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#show context
       meshpoint no-root
       meshid test
       control-vlan 1
       security-mode eap
       no rootnx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#
      nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#root
       meshpoint no-root
       meshid test
       control-vlan 1
       security-mode eap
       root
Related Commands
no (meshpoint-config)
Removes the configuration of this meshpoint device as a root meshpoint
