post-authentication-vlan
Configures the VLAN that is assigned to this captive portal‘s users upon successful authentication
Syntax
post-authentication-vlan [<1-4096>|<VLAN-ALIAS>]
Parameters
Configures the post authentication VLAN. The VLAN specified here is assigned to this captive portal‘s users after they have authenticated and logged on to the network. Provide the VLAN ID, or use an existing VLAN alias to identify the post authentication VLAN.
  • <1-4096> – Specify the VLAN's number from 1 - 4096.
  • <VLAN-ALIAS> – Specify the VLAN alias (should be existing and configured). VLAN alias names begin with a ‘$‘.
rfs4000-229D58(config-captive-portal-test)#post-authentication-vlan 1
rfs4000-229D58(config-captive-portal-test)#show context
captive-portal test
Related Commands
no
Removes the post authentication RADIUS VLAN assigned to this captive portal's users
