alg
Enables traffic filtering at the application layer using the ALG (Application Layer Gateway) feature
Syntax
alg [dns|facetime|ftp|pptp|sccp|sip|tftp]
Parameters
alg
Enables traffic filtering at the application layer. The ALG provides filters for the following common protocols: DNS, Facetime, FTP, PPTP, SCCP, SIP, and TFTP.
dns
Allows DNS (Domain Name System) traffic through the firewall using its default ports. This option is enabled by default.
When enabled, you can easily permit or deny traffic based on a packet‘s DNS name, instead of the IP address. Use this option when configuring ACLs allowing or denying traffic for Web sites that have a single domain name resolving to any one of multiple IP addresses.
facetime
Allows Apple‘s FaceTime video calling traffic through the firewall using its default ports. This option is disabled by default.
ftp
Allows FTP (File Transfer Protocol) traffic through the firewall using its default ports. This option is enabled by default.
pptp Allows PPTP (Point-to-Point Tunneling Protocol) traffic through the firewall using its default ports. PPTP, a network protocol, enables secure transfer of data from a remote client to an enterprise server by encapsulating PPP packets into IP datagrams for transmission over the Internet or other public TCP/IP-based networks. This option is enabled by default.
sccp
Allows SCCP (Signalling Connection Control Part) traffic through the firewall using its default ports. This option is disabled by default.
SCCP is a network protocol that provides routing, flow control and error correction in telecommunication networks.
sip
Allows SIP (Session Initiation Protocol) traffic through the firewall using its default ports. This option is disabled by default.
tftp
Enables the TFTP (Trivial File Transfer Protocol) algorithm. When enabled, allows TFTP traffic through the firewall using its default ports. This option is enabled by default.
nx9500-6C8809(config-fw-policy-testFW)#show context
firewall-policy testFW
 no ip dos tcp-sequence-past-window
 alg facetime
Related Commands
no Removes or reverts ALG related settings
