cert-key-size
Configures the size of the key associated with a certificate request
Syntax
cert-key-size [2048|3072|4096]
Parameters
cert-key-size [2048|3072|4096] Configures the certificate request key size. The options are:
  • 2048 – Sets the key size to 2048 bits. This is the default setting.
  • 3072 – Sets the key size to 3072 bits
  • 4096 – Sets the key size to 4096 bits
nx9500-6C8809(config-cmp-policy-test)#cert-key-size 3072
nx9500-6C8809(config-cmp-policy-test)#show context
crypto-cmp-policy test
 cert-key-size 3072
 ca-server primary host 192.168.8.74 port 8 path cmp
Related Commands
no Reverts the certificate request key size to default (2048 bits)
