antenna-id (ap560h)
Profile Config Commands
Configures the antenna ID on an AP560h model access point profile and device. This command allows you to select the internal antenna modes.
The ExtremeMobility AP560h access point is a dual-radio access point, with eight, internal Wi-Fi antennas, supporting two internal antenna modes: 30 degree and 70 degree.
To enable the AP560h radio, configure the country code, map a WLAN to the radio, and configure the internal antenna mode as '30 degree' or '70 degree'.
Supported in the following platform
Syntax
antenna-id internal [internal-560h-30|internal-560h-70|default]
Parameters
antenna-id Allows you to configure the functional mode for the AP560h access point's internal antennas.
internal States the antenna is internal.
internal-560h-30 Configures the internal antenna mode as 30 degree.
internal-560h-70 Configure the internal antenna mode as 70 degree.
default Sets the antenna mode to default. In this mode, no the antenna-mode is not specified and the radio is disabled. You must set the antenna mode to either 30 degree or 70 degree to turn-on the radios.
Radio Modes Supported
The AP560h supports the following radio modes:
Software Mode 1
  • Radio 1: Set to 2.4 GHz WLAN, Channels 1 - 11 in the 20 MHz /40 MHz bandwidths
  • Radio 2: Set to 5 GHz WLAN, Channels 36 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz
Software Mode 2
  • Radio 1: Set to 2.4/5 GHz Sensor
Software Mode 3
  • Radio 1: Set to 5 GHz, Channels 36 - 64 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths
  • Radio 2: Set to 5 GHz, Channels 100 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths
nx9500-6C8809(config-profile-ap560h)#antenna-id internal internal-560h-70
nx9500-6C8809(config-profile-ap560h)#show context include-factory | include antenna-id
 antenna-id external group-1 default
 antenna-id external group-2 default
Related Commands
no Reverts the antenna mode to default on the selected AP560h profile and device.
