traceroute
Traces the route to a defined destination
Use ‘--help' or ‘-h' to display a complete list of parameters for the traceroute command
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
traceroute <LINE>
Parameters
traceroute <LINE>
traceroute <LINE>
Traces the route to a destination IP address or hostname
  • <LINE> – Specify the destination IPv4 address or hostname.
NOC-NX9500#traceroute 10.234.160.11
traceroute to 10.234.160.11 (10.234.160.11), 30 hops max, 46 byte packets
 1  10.234.160.11 (10.234.160.11)  8.115 ms  0.410 ms  0.370 ms
NOC-NX9500#
