antenna-mode
interface-config-radio-instance
Configures the antenna mode (the number of transmit and receive antennas) on the access point
This command sets the number of transmit and receive antennas on the access point. The 1x1 mode is used for transmissions over just the single -A- antenna, 1xALL is used for transmissions over the -A- antenna and all three antennas for receiving. The 2x2 mode is used for transmissions and receipts over two antennas for dual antenna models. The default setting is dynamic based on the access point model deployed and its transmit power settings.
Syntax
antenna-mode [1*1|1*ALL|2*2|3*3|default]
Parameters
antenna-mode [1*1|1*ALL|2*2|default]
antenna-mode Configures the antenna mode
1*1 Uses only antenna A to receive and transmit
1*ALL Uses antenna A to transmit and receives on all antennas
2*2 Uses antennas A and C for both transmit and receive
Note: AP505i and AP510i are dual antenna access points.
3*3 Uses antenna A, B, and C for both transmit and receive
default Uses default antenna settings. This is the default setting.
Usage Guidelines
Click here for more information on AP505 and AP510 radio and antenna specifications.
For STBC feature support, the antenna-mode should not be configured to 1*1.
ap505-133E1C(config-profile-testap505-if-radio2)#antenna-mode 2x2
ap505-133E1C(config-profile-testap505-if-radio2)#show context
 interface radio2
  mesh client
  antenna-elevation 5.0
  antenna-gain 12.0
  aggregation ampdu tx-only
  aeroscout forward ip 1.23.4.56 port 300
  antenna-mode 2x2
  antenna-diversity
Related Commands
no (radio-interface-config-command) Resets the radio antenna mode (the number of transmit and receive antennas) to its default
