application
Adds an application to this application group. You can add a system-provided or user-defined application.
Syntax
application <APPLICATION-NAME>
Parameters
application <APPLICATION-NAME> Configures the application to be added to this application group
  • <APPLICATION-NAME> – Provide the application name (should be available as an option in the system). A maximum of eight (8) applications can be added to a group.
    Note: If the desired application is not available as an option, use the application command to add it.
To view all applications available in the system, use [TAB], as shown in the following example:
nx9500-6C8809(config-app-group-test)#application [TAB]
Display all 300 possibilities? (y or n)
1-clickshare-com                 1-upload-com
1-upload-to                      10upload-com
--More--
Select the desired application from the list displayed, as shown in the following examples:
nx9500-6C8809(config-app-group-amazon)#application amazon [TAB]
amazon-prime-music  amazon-prime-video  amazon_cloud  amazon_shop
nx9500-6C8809(config-app-group-amazon)#application amazon-prime-music
nx9500-6C8809(config-app-group-amazon)#application amazon-prime-video
nx9500-6C8809(config-app-group-amazon)#application amazon_cloud
nx9500-6C8809(config-app-group-amazon)#application amazon_shop
nx9500-6C8809(config-app-group-amazon)#show context
application-group amazon
Note, the system returns an error message if the application entered is not listed, as shown in the following example:
nx9500-6C8809(config-app-group-test)#application bing
% Error: application 'bing' is not defined
Related Commands
no Removes a specified application from this application group
