Log in to the WiNG Controller
Connect to the device (AP, wireless controller, service platform, or virtual paltform) using either of the following methods:
If this is the first time you are logging in to the controller, be sure to log in using the following credentials:
User Name admin
Password admin123
Use this procedure to establish a CLI session with the device controller.
  1. At the login as: prompt, enter your <username>.
  2. At the administrator's login password: prompt, enter your <password>.
When logging into the CLI for the first time, you are prompted to change the password. Reset the password and use it for subsequent logins.
