ssid-match
Configures the SSID (and its character length) used as a match criteria
Syntax
ssid-match [ssid|ssid-len]
ssid-match [ssid <SSID>|ssid-len <0-32>]
Parameters
ssid <SSID>
Specifies the SSID match string
  • <SSID> – Specify the SSID string.
Note: Specify the correct SSID to ensure proper filtering.
ssid-len <0-32>
Specifies the length of the SSID
  • <0-32> – Specify the SSID length from 0 - 32 characters.
nx9500-6C8809(config-test-signature-test)#ssid-match ssid PrinterLan
nx9500-6C8809(config-test-signature-test)#show context
 signature test
  bssid 11-22-33-44-55-66
  src-mac 00-1E-E5-EA-1D-60
  dst-mac 55-66-77-88-99-00
  frame-type beacon
  filter-ageout 8
  payload 1 pattern test offset 1
Related Commands
no (wips-signature-config-mode-command)
Removes the configured SSID
