rf-domain-manager
Profile Config Commands
Configures the RF Domain manager election criteria
Syntax
rf-domain-manager [capable|priority <1-255>]
Parameters
rf-domain-manager Configures the RF Domain manager election criteria
capable Enables devices using this profile capable of being elected as the RF Domain manager. The RF Domain manager stores and provisions configuration and firmware images for other members of the RF Domain. It also updates state changes, if any, to RF Domain members. This option is enabled by default.
priority <1-255> Assigns a priority value for devices using this profile in the RF Domain manager election process. The higher the number set, higher is the device‘s priority in the RF Domain manager election process.
  • <1-255> – Select a priority value from 1 - 255.
NOC-NX9500(config-profile-testNX9000)#rf-domain-manager capable
NOC-NX9500(config-profile-testNX9000)#show context include-factory | include rf-
domain-manager
 rf-domain-manager priority 1
Related Commands
no Disables or reverts settings to their default
