no
Removes or resets this DHCP user pool‘s settings
Syntax
no [address|bootfile|ddns|default-router|dns-server|domain-name|excluded-address|
  lease|netbios-name-server|netbios-node-type|network|next-server|option|
  respond-via-unicast|static-binding|static-route|update]
no [bootfile|default-router|dns-server|domain-name|lease|netbios-name-server|
  netbios-node-type|next-server|network|respond-via-unicast]
no address [<IP>|<HOST-ALIAS--NAME>|all]
no address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
no ddns [domainname|multiple-user-class|server|ttl]
no excluded-address [<IP|<HOST-ALIAS-NAME>]
no excluded-address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
no option <OPTION-NAME>
no static-binding client-identifier <CLIENT-IDENTIFIER>
no static-binding hardware-address <MAC>
no static-route <IP/MASK> <GATEWAY-IP>
no update dns {override}
Parameters
no bootfile
Removes a BOOTP bootfile configuration
no default-router
Removes the configured default router for the DHCP pool
no dns-server
Removes the configured DNS server for the DHCP pool
no domain-name
Removes the configured DNS domain name
no lease
Resets the lease to its default (24 hours)
no netbios-name-server
Removes the configured NetBIOS name server
no netbios-node-type
Removes the NetBIOS node type
no next-server
Removes the next server utilized in the boot process
no network
Removes the DHCP server network information
no respond-via-unicast
Sets the DHCP offer and ACK as broadcast instead of unicast
no address [<IP>|HOST-ALIAS-NAME|all]
no address
Resets configured DHCP pool addresses
<IP>
Removes an IP address from the list of addresses
<HOST-ALIAS-NAME>
Removes the host alias (used to identify a single host) associated with this DHCP pool‘s address list
all
Removes configured DHCP IP addresses
no address
Resets the DHCP pool addresses
range [<START-IP>| <START-HOST-ALIAS- NAME>] [<END-IP>| <END-HOST-ALIAS- NAME>]
Removes a range of IP addresses and host aliases associated with this DHCP pool‘s address list.
  • <START-IP> – Specify the first IP address in the range.
  • <START-HOST-ALIAS-NAME> – Specify the host alias, mapped to the first IP address in the range.
    • <END-IP> – Specify the last IP address in the range.
    • <END-HOST-ALIAS-NAME> – Specify the host alias, mapped to the last IP address in the range.
Note: The specified IP addresses and host aliases are removed from the DHCP pool‘s address list.
no ddns
Resets DDNS parameters
domainname
Removes DDNS domain name information
multiple-user-class
Resets the use of a multiple user class with the DDNS
server
Removes configured DDNS servers
ttl
Resets the TTL information for DDNS updates
no excluded-address [<IP|HOST-ALIAS-NAME>]
no excluded-address <IP>
Removes an excluded IP address from the list of addresses that cannot be issued by the DHCP server
  • <IP> – Specify the IP address.
<HOST-ALIAS-NAME>
Removes the host alias (used to identify a single host) associated with this DHCP pool‘s excluded-address list
no no excluded-address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
no excluded-address
Removes a range of excluded IP addresses from the list of addresses that cannot be issued by the DHCP server
range [<START-IP>|<START- HOST-ALIAS-NAME>] [<END-IP> <END-HOST-ALIAS- NAME>]
Removes a range of IP addresses and host aliases associated with this DHCP pool‘s excluded address list.
  • Note: The specified IP addresses and host aliases are removed from the DHCP pool‘s excluded address list
no option
Resets DHCP option information
<OPTION-NAME>
Defines the DHCP option
no static-binding
Removes static bindings for DHCP client
Resets client identifier information
  • <CLIENT-IDENTIFIER> – Specify the client identifier.
no static-binding
Removes static bindings for a DHCP client
Resets information based on the hardware address
  • <MAC> – Specify the hardware MAC address.
no static-route
Removes static routes for this DHCP pool
<IP/MASK>
Removes routing information for a particular subnet
<GATEWAY-IP>
Removes the gateway information from a particular subnet‘s routing information
no update dns
Removes DDNS settings
override
  • Optional. Removes DDNS updates from an onboard DHCP server
The following example shows the DHCP pool settings before the ‘no‘ commands are executed:
<exsw5>(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  network 192.168.13.0/24
  address 192.168.13.4 class dhcpclass1
  lease 100 23 59 59
  ddns server 192.168.13.9
  ddns domainname WID
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  domain-name documentation
  netbios-node-type b-node
  bootfile test.txt
            default-router 192.168.13.8 192.168.13.9
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
  next-server 192.168.13.26
<exsw5>(config-dhcp-policy-test-pool-testPool)#no bootfile
<exsw5>(config-dhcp-policy-test-pool-testPool)#no network
<exsw5>(config-dhcp-policy-test-pool-testPool)#no default-router
<exsw5>(config-dhcp-policy-test-pool-testPool)#no next-server
<exsw5>(config-dhcp-policy-test-pool-testPool)#no domain-name
<exsw5>(config-dhcp-policy-test-pool-testPool)#no ddns domainname
<exsw5>(config-dhcp-policy-test-pool-testPool)#no lease
The following example shows the DHCP pool settings after the ‘no‘ commands are executed:
 dhcp-pool testPool
Related Commands
address
Configures the DHCP server‘s IP address pool
bootfile
Configures the BOOTP boot file path
ddns
Configures DDNS for use with this DHCP pool
default-router
Configures default routers for this DHCP pool
dns-server
Configures default DNS servers for this DHCP pool
domain-name
Configures the DDNS domain name for this DHCP pool
excluded-address
Configures IP addresses assigned as static addresses
lease
Configures the DHCP lease settings
netbios-name-server
Configures the NetBIOS name server
netbios-node-type
Configures the NetBIOS node type
network
Configures the DHCP server‘s network settings
next-server
Configures the next server in the BOOTP boot process
option
Configures the DHCP option
respond-via-unicast
Configures how a DHCP request and ACK are sent
static-binding
Configure static binding information
static-route
Configures static routes installed on DHCP clients
update
Controls DDNS service usage
