no (ex3500-qos-class-map-policy-config-commands)
description
Removes this EX3500 QoS class map policy‘s description and match criteria
  • Service Platforms — NX 7510, NX 95XX, NX 96XX
Syntax
no [description|match]
no description
no match [access-list [ex3500-ext-access-list|ex3500-std-access-list|mac-acl]
<ACL-NAME>|cos <0-7>|ip [dscp <0-63>|precedence <0-7>]|ipv6 dscp <0-63>|vlan <1-4094>]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes the EX3500 QoS class map policy‘s settings based on the parameters passed
The following example shows the EX3500 QoS class map policy ‘test‘ settings before the ‘no‘ command are executed:
nx9500-6C8809(config-ex3500-qos-class-map-policy-dscp)#show context
ex3500-qos-class-map-policy dscp
 description "Matches packets marked for DSCP service 3"
 match ip dscp 3
nx9500-6C8809(config-ex3500-qos-class-map-policy-dscp)#no description
nx9500-6C8809(config-ex3500-qos-class-map-policy-dscp)#no match ip dscp
The following example shows the EX3500 QoS class map policy ‘test‘ settings after the ‘no‘ command are executed:
ex3500-qos-class-map-policy test
