channel (iot-device-type-imagotag-policy)
Manually configures the channel assigned for the ESL communicator to tag communication in the 2.4 GHz band. Or, enables ACS (Auto-Channel Selection) mode.
Syntax
channel [<0-10>|acs]
Parameters
channel [<0-10>|acs] Configures the 2.4 GHz frequency channel, using one of the following options:
  • <0-10> – Manually configures the channel from 0 - 10.
  • acs – Enables ACS channel selection mode. This is the default setting.
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#channel 9
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  channel 9
Related Commands
no (iot-device-type-imagotag-policy) Reverts the channel selection mode to ACS
