access-network-type
Configures the access network type for this hotspot. The beacons and probe responses communicate the type of hotspot (public, private, guest-use, emergency, etc.) to clients seeking access.
Syntax
access-network-type [chargeable-public|emergency-services|experimental|free-public|
personal-device|private|private-guest|wildcard]
Parameters
access-network-type
Select the access network type for this hotspot. The options are:
  • chargeable-public – The network type is a chargeable public network.
  • emergency-services – The network is used to provide emergency services only.
  • experimental – The network is used for test or experimental purposes only.
  • free-public – The network type is a free public.
  • personal-device – The network is used for personal devices only.
  • private – The network is a private network.
  • private-guest – The network is a private network with guest access (default setting),
  • wildcard – Includes all access network types.
Note: If the network type is set to chargeable-public, probe responses advertise this hotspot as a chargeable-public hotspot.
nx9500-6C8809(config-passpoint-policy-test)#access-network-type chargeable-public
nx9500-6C8809(config-passpoint-policy-test)#show context
hotspot2-policy test
 3gpp mcc 310 mnc 970
 3gpp mcc 505 mnc 14
Related Commands
no Reverts to the default access network type setting (private)
