device
Enables simultaneous configuration of multiple devices
Syntax
device {containing|filter}
device {containing <STRING>} {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|
nx75xx|nx9000|nx9600|t5|vx9000]}
device {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|nx75xx|nx9000|nx9600|
t5|vx9000]}
Parameters
device {containing <STRING>} {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|nx75xx|nx9000|nx9600|
t5|vx9000]}
device
Enters a device‘s configuration mode. Use this command to simultaneously configure devices having similar configuration.
containing <STRING>
Optional. Configures the string to search for in the device‘s hostname. All devices having hostnames containing the string specified here are filtered, and can be configured simultaneously.
  • <STRING> – Specify the string to search for in the device‘s hostname.
filter type <DEVICE-TYPE> Optional. Filters out a specific device type. After specifying the hostname string, select the device type. The options are: AP510, AP505, EX3424, EX3548, RFS4000, NX5500, NX7500, NX9500, NX9600, VX9000, and T5.
t5|vx9000]}
device
Configures a basic device profile
filter type <DEVICE-TYPE> Optional. Filters out a specific device type. The options are: AP510, AP505, EX3424, EX3548, RFS4000, NX5500, NX7500, NX9500, NX9600, VX9000, and T5..
ap505-13403B(config)#device filter type ap5
ap510  ap505
ap505-13403B(config)#device filter type ap505 ?
  <cr>
ap505-13403B(config-device-{'type': 'ap505'})#
Related Commands
no
Removes multiple devices from the network
