gre
Profile Config Commands
Enables Generic Routing Encapsulation (GRE) tunneling or tunnel concentrator operation on this profile.
Syntax
gre {concentrator׀tunnel}
Parameters
gre concentrator
Use this command to enter GRE Concentrator Tunnel Mode and configure settings to enable GRE tunneling between APs and ExtremeWireless WiNG controllers.
With this feature, an AP acts as GRE initiator and creates wireless client tunnels to an ExtremeWireless WiNG that is operating as a GRE concentrator tunnel terminator.
Use this command to modify an existing GRE concentrator‘s settings.
gre tunnel Use this command to enter GRE Tunnel Mode, and to create up to 1000 GRE tunnels. Use this command to modify an existing GRE tunnel‘s settings.
vx9000-AA3AED(config-profile-gre-conc-tunnel)#gre ?
  concentrator  Configure concentrator gre tunnel policy
  tunnel        Create / modify GRE tunnel
