management-server
Profile Config Commands
Configures a management server with this profile. This command is also applicable to the device configuration context.
Syntax
management-server <HOST-NAME> port <1-65535>
Parameters
management-server <HOST-NAME> port <1-65535> Configures a management server with this profile. Use this command to identify the management server.
  • <HOST-NAME> – Specify the management server‘s host name.
    • port <1-65535> – Specify the port where the management server is reachable. The default setting is port 443.
Note: If the adoption-mode, on this profile, is set to ‘cloud‘, ensure that the management-server configuration points to the ExtremeCloud Web address. If the adoption-mode is set to ‘ws-controller‘, provide the ExtremeCloud Appliance controller‘s IP address or hostname as the management server. For information on configuring the adoption-mode, see adoption-mode.
nx9500-6C8809(config-profile-TestAP8533)#management-server nx9500-6C8809 port 300
nx9500-6C8809(config-profile-TestAP8533)#show context include-factory | include management-server
Related Commands
no Removes the management server configuration
