iot-device-type-imagotag-policy config commands
The following table summarizes IoT Device-Type Imagotag policy configuration mode commands:
Table 1. IoT-Device-Type Imagotag Policy Config Commands
Command Description
channel (iot-device-type-imagotag-policy) Configures the channel assigned for ESL communicator to tag communication in the 2.4 GHz band
enable (iot-device-type-imagotag-policy) Enables the ESL communicator
fcc-mode (iot-device-type-imagotag-policy) Enables the FCC compatibility mode on the ESL communicator
output-power (iot-device-type-imagotag-policy) Configures the maximum output power for the ESL communicator
payload-size (iot-device-type-imagotag-policy) Configures the maximum payload size in packets exchanged between ESL communicator and tags
server (iot-device-type-imagotag-policy)
Configures the ESL SES-Imagotag server‘s hostname or IP address
ssl (iot-device-type-imagotag-policy) Enables SSL (Secure Socket Layer) encryption mode of communication between the AP and the SES-imagotag server.
window-size (iot-device-type-imagotag-policy) Configures the transmission window size for messages exchanged between ESL communicator and tags.
no (iot-device-type-imagotag-policy) Reverts this IoT Device-Type Imagotag policy settings to default values
