t5
Invokes the configuration mode of a t5 wireless controller
Syntax
t5 <T5-DEVICE-MAC>
Parameters
t5 <T5-DEVICE-MAC>
t5 <T5-DEVICE-MAC> Specify the T5 device‘s MAC address. The system enters the identified device‘s configuration mode.
A T5 controller uses the IPX operating system to manage its connected radio devices, as opposed to the T5 operating system used by wireless controllers, and service and virtual platforms. However, a T5 controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within a WiNG supported subnet populated by both types of devices. The Customer Premises Equipments (CPEs) are the T5 controller managed radio devices using the IPX operating system. These CPEs use a DSL (Digital Subscriber Line) as their high speed Internet access mechanism using the CPE‘s physical wallplate connection and phone jack.
After logging on to the T5 device, use the ‘cpe‘ keyword and configure the following mandatory settings:
  • vlan – Set a VLAN from 1 - 4,094 used as a virtual interface for connections between the T5 controller and its managed CPE devices.
  • start ip – Set a starting IP address used in a range of addresses available to T5 controller connecting CPE devices.
  • end ip – Set an end IP address used in a range of addresses available to T5 controller connecting CPE devices.
nx9500-6C8809(config)#t5 B4:C7:99:ED:5C:2C
nx9500-6C8809(config-device-B4:C7:99:ED:5C:2C)#?
T5 Device Mode commands:
  adsp-sensor-server  Configure WIPS server
  bridge              Sets MAC address expiration time in the bridge address
                      table
  clock               Configure clock options
  cpe                 T5 CPE configuration
  hostname            Set system's network name
  interface           Select an interface to configure
  ip                  Internet Protocol (IP)
  no                  Negate a command or set its defaults
  ntp                 Configure NTP
  override-wlan       Configure RF Domain level overrides for wlan
  password            T5 password configuration
  qos                 QOS settings
  radius-server       Radius server settings
  t5                  T5 configuration
  t5-logging          Modify message logging facilities
  use                 Set setting to use
  clrscr              Clears the display screen
  commit              Commit all changes made in this session
  do                  Run commands from Exec mode
  end                 End current mode and change to EXEC mode
  exit                End current mode and down to previous mode
  help                Description of the interactive help system
  revert              Revert changes
  service             Service Commands
  show                Show running system information
  write               Write running configuration to memory or terminal
Related Commands
no Removes the T5 wireless controller identified by the device‘s MAC address
