configure
Enters the configuration mode. Use this command to enter the current device's configuration mode, or enable configuration from the terminal.
Syntax
configure {self|terminal}
Parameters
self
Optional. Enables the logged-in device's configuration mode
terminal
Optional. Enables configuration from the terminal
ap505-13403B#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
ap505-13403B(config)#
nx9500-6C8809#configure self
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#
