ip
      Creates an access control list
         (ACL) and enters its configuration mode. Access lists define access permissions to the
         network using a set of rules. Each rule specifies an action taken when a packet matches the
         rule. If the action is deny, the packet is dropped. If the action is permit, the packet is
         allowed.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Syntax
         ip [access-list|ex3500-ext-access-list|ex3500-std-access-list|snmp-access-list]
         ip ex3500-ext-access-list <EX3500-EXT-ACL-NAME>
         ip ex3500-std-access-list <EX3500-STD-ACL-NAME>
         ip access-list <IP-ACL-NAME>
         ip snmp-access-list <IP-SNMP-ACL-NAME>
      Parameters
                     | access-list <IP-ACL-NAME> |
                     Creates an IP ACL and enters its configuration
                           mode
                           - <IP-ACL-NAME> – Specify the ACL name. If the
                              access list does not exist, it is created.
                     | ex3500-ext-access-list <EX3500-EXT-ACL-NAME> |
                     Creates an EX3500 Extended ACL and enters its configuration mode
                           - <EX3500-EXT-ACL-NAME> – Specify the ACL name. If an ACL with the
                              specified name does not exist, it is created.
                     | ex3500-std-access-list <EX3500-STD-ACL-NAME> |
                     Creates an EX3500 Standard ACL and enters its configuration mode
                     | snmp-access-list <IP-SNMP-ACL-NAME> |
                     Creates a SNMP IP ACL and enters its configuration mode. An SNMP IP ACL
                        is an access control mechanism that uses a combination of IP ACL and SNMP
                        community string. SNMP performs network management functions using a data
                           structure called a MIB. SNMP is widely implemented but not very secure,
                           since it uses only text community strings for accessing controller or
                           service platform configuration files.
Use SNMP ACLs (firewalls) to
                           help reduce SNMP‘s vulnerabilities, as SNMP traffic can be easily
                           exploited to produce a DoS.
                              - <IP-SNMP-ACL-NAME> – Specify the SNMP IP ACL name. If the
                                 access list does not exist, it is created. After creating the SNMP
                                 ACL, define the deny/permit rules based on the network and/or host
                                 IP addresses. Once created and configured, link this SNMP IP ACL
                                 with a SNMP community string.
To link the SNMP community string with the SNMP IP ACL, in
                           the management-policy-config-mode, use the following command:
                              snmp-server > community <COMMUNITY-STRING> >
                              [ro|rw] > ip-snmp-access-list
                           <IP-SNMP-ACL-NAME>.
         nx9500-6C8809(config)#ip access-list test
nx9500-6C8809(config-ip-acl-test)#?
ACL Configuration commands:
  deny     Specify packets to reject
  disable  Disable rule if not needed
  no       Negate a command or set its defaults
  permit   Specify packets to forward
  clrscr   Clears the display screen
  commit   Commit all changes made in this session
  end      End current mode and change to EXEC mode
  exit     End current mode and down to previous mode
  help     Description of the interactive help system
  revert   Revert changes
  service  Service Commands
  show     Show running system information
  write    Write running configuration to memory or terminal
         nx9500-6C8809(config)#ip snmp-access-list SNMPAcl
nx9500-6C8809(config-ip-snmp-acl-SNMPAcl)#?
SNMP ACL Configuration commands:
  do       Run commands from Exec mode
      Related Commands
                     | no
                     Removes an existing IP access control list |
