client-client-communication
Allows frame switching from one client to another on a WLAN. This option is enabled by default. It allows clients to exchange packets with other clients. It does not necessarily prevent clients on other WLANs from sending packets to this WLAN, but as long as this setting is also disabled on that WLAN, clients are not permitted to interoperate.
Syntax
Parameters
None
nx9500-6C8809(config-wlan-1)#client-client-communication
Related Commands
no (wlan-config-mode) Disables frame switching from one client to another on a WLAN
