vlan-pool-member
Adds a member VLAN to a WLAN‘s VLAN pool. Use this option to define the VLANs available to this WLAN. Additionally, define the number of wireless clients supported by each VLAN.
Configuration of a VLAN pool overrides the 'vlan' configuration.
Syntax
vlan-pool-member <WORD> {limit <0-8192>}
Parameters
vlan-pool-member Adds a member VLAN to a WLAN's VLAN pool
Since users belonging to separate VLANs can share the same WLAN, it is not necessary to create a new WLAN for every VLAN in the network.
<WORD> Define the VLANs available to this WLAN. It is either a single index, or a list of VLAN IDs (for example, 1,3,7), or a range (for example, 1-10)
limit <0-8192> Optional. Is ignored if the number of clients are limited and well within the limits of the DHCP pool on the VLAN
  • <0-8192> – Specifies the number of users allowed
nx9500-6C8809(config-wlan-test)#vlan-pool-member 1-10 limit 1
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid testWLAN1
 vlan-pool-member 1 limit 1
 vlan-pool-member 2 limit 1
 vlan-pool-member 3 limit 1
 vlan-pool-member 4 limit 1
 vlan-pool-member 5 limit 1
 vlan-pool-member 6 limit 1
 vlan-pool-member 7 limit 1
 vlan-pool-member 8 limit 1
 vlan-pool-member 9 limit 1
 vlan-pool-member 10 limit 1
 bridging-mode local
 encryption-type none
 authentication-type none
 protected-mgmt-frames mandatory
 radius vlan-assignment
 time-based-access days weekdays start 10:00 end 16:30
--More--
Related Commands
no (wlan-config-mode) Removes the list of VLANs mapped to a WLAN
