application-group
Creates an application group and enters its configuration mode. An application group is a collection of system-provided and/or user-defined applications. It is a subset of the total number of supported applications. Use this command to create and application group. It is always easier to create deny and allow rules that can be collectively applied collectively to a group of applications rather than creating rules for individual applications.
Application group is a means of selectively denying or allowing access to set of applications within a specific app-category.
The WiNG 7.1.X release does not support DPI (application visibility) on AP5XX model access points.
Supported on the following pltaforms:
Syntax
application-group <APPLICATION-GROUP-NAME>
Parameters
application-group <APPLICATION-GROUP-NAME> Creates an application group and enters its configuration mode
  • <APPLICATION-GROUP-NAME – Specify the application group name. If an application group with the specified name does not exist, it is created. The name should not exceed 32 characters in length.
nx9500-6C8809(config)#application-group amazon
nx9500-6C8809(config-app-group-amazon)#?
Application Group Mode commands:
  application  Add application to group
  description  Add application-group description
  no           Negate a command or set its defaults
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
Related Commands
no Removes an existing application group
