idle-timeout
gre concentrator
Sets the GRE tunnel inactivity timeout.
Syntax
vx9000-AA3AED(config-profile gre-gre-concentrator-greTest)#idle-timeout <120-3600>
Parameters
<120–3600> Timeout interval in seconds. The default value is 300 seconds.
vx9000-AA3AED(config-profile gre-gre-concentrator-greTest)#idle-timeout 301
vx9000-AA3AED(config-profile gre-gre-concentrator-greTest)#show context
 gre concentrator greTest
  idle-timeout 301
  allowed-vlan 97-99
If the idle-timeout setting is the default value (300), it does not display when the show context command is issued.
Related Commands
no Negate a command or set its defaults
