absolute
Configures an absolute time range rule for this EX3500 time range list. Absolute time ranges are not periodic and do not recur. They consist of a range of days during a particular time period.
Syntax
absolute start <0-23> <0-59> <1-31> <MONTH> <2013-2037> {end <0-23> <0-59> <1-31>
<MONTH> <2013-2037>}
Parameters
absolute Configures an absolute time range rule settings
start <0-23> <0-59> <1-31> <MONTH> <2013-2037> Configures the start day and time settings
  • <0-23> – Specify the start time from 0 - 23 hours.
    • <0-59> – Specify the start time from 0 - 59 minutes.
For example, if the values provided are 12 hours and 30 minutes, the start time is 12:30 A.M on the specified day.
  • <1-31> – Specify the day of month from 1 - 31 when the time range starts.
    • <MONTH> – Specify the month. The options are: April, August, December, February, January, July, June, March, May, November, October, September.
      • <2013-2037> – Specify the year from 2013 - 2037.
end <0-23> <0-59> <1-31> <MONTH> <2013-2037> Optional. Configures the end day and time settings
  • <0-23> – Specify the end time from 0 - 23 hours.
    • <0-59> – Specify the end time from 0 - 59 minutes.
  • <1-31> – Specify the day of month from 1 - 31 when the time range ends.
EX3500(config-ex3500-time-range-EX3500-TimeRange-01)#absolute start 1 0 1
 june 2017 end 1 0 30 june 2018
EX3500(config-ex3500-time-range-EX3500-TimeRange-01)#show context
ex3500 time-range EX3500-TimeRange-01
 absolute start 1 0 1 june 2018 end 1 0 30 june 2018
Related Commands
no (ex3500-time-range-config-mode) Removes this absolute time range rule from the EX3500 time range list
