accelerated-multicast
Configures the accelerated multicast stream address and forwarding QoS classification
Syntax
accelerated-multicast [<IP>|autodetect]
accelerated-multicast [<IP>|autodetect] {classification [background|best-effort|
trust|video|voice]}
Parameters
trust|video|voice]}
<IP>
Configures a multicast IP address in the A.B.C.D format. The system can configure up to 32 IP addresses for each WLAN QoS policy
autodetect
Allows the system to automatically detect multicast streams. This parameter allows the system to convert multicast streams to unicast, or to specify multicast streams converted to unicast.
classification
Optional. Configures the forwarding of the QoS classification (traffic class). When the stream is converted and queued for transmission, specify the type of classification applied to the stream. The options are: background, best-effort, trust, voice, and video.
background
Forwards streams with background (low) priority. This parameter is common to both <IP> and autodetect.
best-effort
Forwards streams with best effort (normal) priority. This parameter is common to both <IP> and autodetect.
trust
No change to the streams forwarding traffic class. This parameter is common to both <IP> and autodetect.
video
Forwards streams with video traffic priority. This parameter is common to both <IP> and autodetect.
voice
Forwards streams with voice traffic priority. This parameter is common to both <IP> and autodetect.
nx9500-6C8809(config-wlan-qos-test)#accelerated-multicast autodetect
classification voice
nx9500-6C8809(config-wlan-qos-test)#show context
wlan-qos-policy test
 qos trust dscp
 qos trust wmm
 accelerated-multicast autodetect classification voice
