sensitivity
Configures Smart RF sensitivity level. The sensitivity level determines Smart RF scanning and sampling aggressiveness. For example, a low sensitivity level indicates a less aggressive Smart-RF policy. This translates to fewer samples taken during off-channel scanning and short off-channel durations. When the sensitivity level is set to high, Smart-RF collects more samples, and remains off-channel longer.
The Smart RF sensitivity level options include low, medium, high, and custom. The custom option allows you to adjust the parameters and thresholds for interference recovery, coverage hole recovery, and neighbor recovery. However, the low, medium, and high settings still allow utilization of these features.
Syntax
sensitivity [custom|high|low|medium]
Parameters
sensitivity Configures Smart RF sensitivity levels. The options available are: custom, high, low, and medium.
custom Enables custom interference recovery, coverage hole recovery, and neighbor recovery as additional Smart RF options
high High sensitivity
low Low sensitivity
medium Medium sensitivity. This is the default setting.
Usage Guidelines
To enable the power and channel setting parameters, set sensitivity to custom or medium.
To enable the monitoring and scanning parameters, set sensitivity to custom.
To enable the neighbor recovery, interference and coverage hole recovery parameters, set sensitivity to custom.
nx9500-6C8809(config-smart-rf-policy-test)#sensitivity high
nx9500-6C8809(config-smart-rf-policy-test)#show context
smart-rf-policy test
 area test channel-list 2.4GHz 1,2,3
 group-by floor
 sensitivity high
 channel-list 2.4GHz 1,12
 channel-width 5GHz auto
 smart-ocs-monitoring frequency 5GHz 3
 smart-ocs-monitoring frequency 2.4GHz 3
 smart-ocs-monitoring sample-count 5GHz 3
 smart-ocs-monitoring sample-count 2.4GHz 3
 --More--
