logging
Configures enhanced firewall logging
Syntax
logging [icmp-all|icmp-packet-drop|malformed-packet-drop|verbose]
logging icmp-all
logging verbose
logging [icmp-packet-drop|malformed-packet-drop] [all|rate-limited]
Parameters
logging icmp-all
logging Configures enhanced firewall logging parameters
icmp-all Enables logging of all ICMPv4/v6 packets allowed by the firewall. This option is disabled by default.
logging verbose
logging
Configures enhanced firewall logging. This option is disabled by default.
verbose
Enables verbose logging
logging
icmp-packet-drop
Enables logging of ICMP (ICMPv4 and ICMPv6) packets that do not pass sanity checks. The default is none.
Enables logging of raw IP (IPv4 and IPv6) packets that do not pass sanity checks. The default is none.
all
Logs all messages
rate-limited
Enables rate-limited logging. This option sets the rate limit for log messages to one message every 20 seconds.
nx9500-6C8809(config-fw-policy-testFW)#logging verbose
nx9500-6C8809(config-fw-policy-testFW)#logging icmp-packet-drop rate-limited
nx9500-6C8809(config-fw-policy-testFW)#logging malformed-packet-drop all
nx9500-6C8809(config-fw-policy-testFW)#show context
firewall-policy testFW
 ip dos fraggle drop-only
 ip dos tcp-sequence-past-window drop-only
 ip dos tcp-max-incomplete high 600
 ip dos tcp-max-incomplete low 60
 ip-mac conflict drop-only
 ip-mac routing conflict log-and-drop log-level notifications
 flow timeout icmp 16000
 flow timeout udp 10000
 flow timeout tcp established 1500
 flow timeout other 16000
 dhcp-offer-convert
 ipv6 routing-type two log-and-drop log-level warnings
 ipv6 dos hop-limit-zero drop-only
 alg facetime
 logging verbose
 dns-snoop entry-timeout 1200
 ipv6-mac routing conflict drop-only
nx9500-6C8809(config-fw-policy-test2)#show context
firewall-policy test2
 no ip dos tcp-sequence-past-window
nx9500-6C8809(config-fw-policy-test2)#logging icmp-all
 logging icmp-all
Related Commands
no
Disables enhanced firewall logging
