cert-renewal-timeout
Configures a certificate renewal timeout in days. This is the number of days, before the expiration of the device‘s certificate, that a certificate renewal is triggered.
The expiration of device‘s certificate is checked once a day. When a certificate is about to expire a certificate renewal is initiated with the dedicated CMP CA server resource through an existing IPSec tunnel. If the tunnel is not established, the CMP renewal request is not sent. If a renewal succeeds the newly obtained certificate overwrites an existing certificate. If the renewal fails, an error is logged.
Syntax
cert-renewal-timeout <1-60>
Parameters
cert-renewal-timeout <1-60> Configures the certificate renewal timeout in days. This is the number of days, before the expiration of the device‘s certificate, that a certificate renewal is triggered. Once the configured time is completed, the device triggers a certificate renewal request.
  • <1-60> – Specify a value from 1 - 60 days. The default is fourteen (14) days. Therefore, by default a device triggers certificate renewal request 14 days before its certificate expires.
ap6522-D8273A(config-cmp-policy-CMP)#cert-renewal-timeout 60
ap6522-D8273A(config-cmp-policy-CMP)#show context
crypto-cmp-policy CMP
 ca-server primary host 192.168.8.74 port 8 path cmp
Related Commands
no Reverts the certificate renewal timeout to default (14 days)
