authentication
Specifies an authentication scheme used for an OSPF area used with the OSPF dynamic route
Syntax
authentication [message-digest|simple-password]
Parameters
message-digest Configures a message-digest (MD-5) authentication scheme
simple-password Configures a simple password authentication scheme
Usage Guidelines
OSPF packet authentication enables routers to use predefined passwords and participate within a routing domain. The two authentication modes are:
  • MD-5 – MD-5 authentication is a cryptographic authentication mode, where every router has a key (password) and key-id configured on it. This key and key-id together form the message digest that is appended to the OSPF packet.
  • Simple Password – Simple password authentication allows a password (key) to be configured per area. Routers in the same area and participating in the routing domain have to be configured with the same key.
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#authentication simple-password
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#show context
  area 0.0.0.1
   area-type stub default-cost 1
Related Commands
no (area-config-mode-command) Removes the authentication scheme assoictaed with this area
