no (bluetooth-inf-config-command)
interface-config-bluetooth-instance
Removes or reverts to default this AP8432/AP8533 Bluetooth radio interface‘s settings
Syntax
no [beacon|description|eddystone|ibeacon|mode|shutdown]
no beacon [pattern|period]
no description
no eddystone [calibration-rssi|url [1|2]
no ibeacon [calibration-rssi|major|minor|uuid]
no mode
no shutdown
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or reverts to default this Bluetooth radio interface‘s settings based on the parameters passed
  • <PARAMETERS> – Specify the parameters.
The following example shows the AP8432 default profile‘s Bluetooth radio interface settings:
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  mode le-beacon
  beacon pattern ibeacon
  ibeacon calibration-rssi -70
  ibeacon major 1110
  ibeacon minor 2210
  ibeacon uuid f2468da65fa82e841134bc5b71e0893e
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#no shutdown
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#no ibeacon minor
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#no ibeacon calibration-rssi
The following example shows the AP8432 default profile‘s Bluetooth radio interface settings after the ‘no‘ commands are executed:
  no shutdown
  mode le-beacon
  ibeacon major 1110
