purview-application-group
Global Configuration Commands
Creates a Purview Application Group and enters its configuration mode. A Purview application group is a collection of system-provided and/or user-defined application definitions. Application group allows you to enforce mandatory stats reporting for specific traffic types.
Extreme Network's AP5xx model APs, running WiNG 7.1.2 and later versions of the WiNG 7 OS, use ExtremeAnalytics for ExtremeCloud IQ - Site Engine (Purview™) libDPI engine to implement Application Visibility and Control (AVC) within a managed network. libDPI detects top-level hosting applications along with the services these applications host.
Use AVC to implement:
  • Packet filtering - allow, deny, mark, or rate-limit packets based on rules defined in the Purview application policy.
  • Mandatory stats reporting - enable mandatory stats reporting for an application or set of applications defined in the Purview application group. See Enabling Mandatory Stats Reporting.
Legacy WiNG devices, running WiNG 5.9.X or WiNG 7.2.1 do not support Purview libDPI engine. Legacy WiNG devices use a third-party, DPI engine to enforce AVC within the managed network. For more information on configuring AVC on legacy devices, see application-policy and application-group.
These legacy devices are: AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432, AP8533, NX500, NX7500, NX9500, NX9600 and VX9000.
Syntax
purview-application-group <PURVIEW-APP-GROUP-NAME>
Parameters
purview-application-group <PURVIEW-APP-GROUP-NAME> Creates a Purview application group and enters its configuration mode
  • <PURVIEW-APP-GROUP-NAME – Specify the application group name. If a Purview application group with the specified name does not exist, it is created. The name should not exceed 32 characters in length.
The purview-application-group command is part of the mandatory stats reporting feature. To enable mandatory stats reporting, follow the steps below:
  1. Create a Purview application group, specify the applications for which mandatory stats reporting is to be enabled.
    If the required application definition is not system-provided, create a custom application signature. For information on creating custom application signatures, see application
  2. Enforce mandatory stats reporting for this Purview application group in the NSight policy.
    For more information and examples, see the mandatory command in the NSight policy context.
  3. Apply the NSight policy in the RF Domain context.
    For more information, see use (rf-domain-config-mode).
nx9500-6C8809(config)#purview-application-group PurvAppGrp
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#?
Purview Application Group Mode commands:
  application  Add application to group
  description  Add application-group description
  no           Negate a command or set its defaults
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
Related Commands
no (global-config-mode) Removes an existing Purview application group
application Creates an application definition and enters its configuration mode.
purview-application-policy Creates a Purview application policy and enters its configuration mode.
nsight-policy (global-config-mode) Creates an NSight policy and enters its configuration mode.
