edit
Edits a text file on the device's file system
Syntax
edit <FILE>
Parameters
edit <FILE>
<FILE> Specify the name of the file to modify.
ap510-133B38#edit startup-config
  GNU nano 1.2.4                File: startup-config
! Configuration of AP510 version 7.3.1.0-001D
version 2.7
ip snmp-access-list default
 permit any
firewall-policy default
 no ip dos tcp-sequence-past-window
mint-policy global-default
wlan-qos-policy default
 qos trust dscp
 qos trust wmm
                               [ Read 132 lines ]
^G Get Help  ^O WriteOut  ^R Read File ^Y Prev Page ^K Cut Text  ^C Cur Pos
^X Exit      ^J Justify   ^W Where Is  ^V Next Page ^U UnCut Txt ^T To Spell                   ^U UnCut Txt                   ^T To Spell
