time-it
Verifies the time taken by a particular command between request and response
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
time-it <COMMAND>
Parameters
time-it <COMMAND>
time-it <COMMAND>
Verifies the time taken by a particular command to execute and provide a result
  • <COMMAND> – Specify the command.
ap505-13403B#time-it config terminal
Enter configuration commands, one per line.  End with CNTL/Z.
That took 0.00 seconds..
ap505-13403B(config)#
