crypto
interface-config-vlan-instance
Associates an existing and configured VPN crypto map with this VLAN interface.
Crypto map entries are sets of configuration parameters for encrypting packets that pass through the VPN tunnel. For more information on crypto maps, see crypto-map-config-commands.
Syntax
crypto map <CRYPTO-MAP-NAME>
Parameters
map <CRYPTO-MAP-NAME> Attaches a crypto map to the selected VLAN interface. The crypto map should be existing and configured.
  • <CRYPTO-MAP-NAME> – Specify the crypto map name.
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#crypto map map1
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#show context
 interface vlan8
  crypto map map1
Related Commands
no Disables or reverts interface VLAN settings to their default
