meshid (meshpoint-config)
Configures a unique SSID (Service Set Identifier) for this meshpoint. This ID is used to uniquely identify this meshpoint.
Syntax
meshid <MESH-SSID>
Parameters
meshid <MESH-SSID>
meshid
Configures a unique SSID for the meshpoint
<MESH-SSID>
The unique SSID configured for this meshpoint
Note: The mesh SSID is case sensitive and should not exceed 32 characters.
nx9500-6C8809(config-meshpoint-test)#meshid TestingMeshPoint
nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
 description "This is an example of a meshpoint description"
 beacon-format mesh-point
 control-vlan 1
 allowed-vlans 1,10-16,18-23
 data-rates 2.4GHz bgn
 data-rates 5GHz an
 security-mode none
 no root
Related Commands
no (meshpoint-config)
Removes the SSID configured for this meshpoint
