qos-map
Enables support for 802.11u QoS map element and frames
Syntax
qos-map
Parameters
None
nx9500-6C8809(config-wlan-test)#qos-map
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode tunnel
 encryption-type none
 authentication-type none
 qos-map
 wpa-wpa2 server-only-authentication
 proxy-nd-mode strict
 opendns device-id 44-55-66
Related Commands
no (wlan-config-mode) Disables support for 802.11u QoS map element and frames
