threshold-client
Configures the client threshold limit. This is the threshold limit per client that, when exceeded, signals the event.
Syntax
threshold-client <1-65535>
Parameters
  • <1-65535> – Set the threshold limit for a 60 second window from 1 - 65535.
nx9500-6C8809(config-test-signature-test)#threshold-client 88
nx9500-6C8809(config-test-signature-test)#show context
 signature test
  bssid 11-22-33-44-55-66
  src-mac 00-1E-E5-EA-1D-60
  dst-mac 55-66-77-88-99-00
  frame-type beacon
  ssid-match ssid PrinterLan
  filter-ageout 8
  threshold-client 88
  payload 1 pattern test offset 1
Related Commands
no (wips-signature-config-mode-command)
Removes the client threshold limit configured with a WIPS policy signature
