terms-agreement
Enforces the user to agree to terms and conditions (included in the login page) for captive portal access. This feature is disabled by default.
When enabled, the system enforces a previously registered user to re-confirm the terms of agreement, on successive log ins, only if the interval between the last log out and the current log in exceeds the agreement-refresh timeout configured in the WLAN context. For more information on configuring the agreement-refresh timeout value, see registration.
Syntax
terms-agreement
Parameters
None
nx9500-6C8809(config-captive-portal-test)#terms-agreement
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 access-time 35
 custom-auth info bob bob@examplecompany.com
 connection-mode https
 inactivity-timeout 750
 server host 172.16.10.9
 simultaneous-users 5
 terms-agreement
Related Commands
no
Resets or disables captive portal commands
