fallback-channel
interface-config-radio-instance
Configures the channel to which the radio switches in case of radar detection on the current channel
Syntax
fallback-channel [100|100w|100ww|104|104w|104ww|108|108w...............74]
Parameters
fallback-channel [100|100w|...........] Configures the fallback channel. This is the channel the radio switches to in case a radar is detected on the radio‘s current operating channel.
  • [100|100w|100ww|...] – Select the fall back channel from the available options.
nx9500-6C8809(config-profile-testAP510-if-radio2)#fallback-channel 104
NOTE: Functionality is supported only in the US regulatory domain and only a non-dfs channel can be configured as a fallback channel
nx9500-6C8809(config-profile-testAP510-if-radio2)#show context
 interface radio2
Related Commands
no (radio-interface-config-command) Removes the fallback-channel configuration
