antenna-diversity
interface-config-radio-instance
Enables antenna diversity for transmit frames at non-11n transmit rates
Antenna diversity uses two or more antennas to increase signal quality and strength. This option is disabled by default.
Syntax
antenna-diversity
Parameters
None
nx9500-6C8809(config-profile-505TestProfile-if-radio1)#antenna-diversity
nx9500-6C8809(config-profile-505TestProfile-if-radio1)#show context
 interface radio1
  aggregation ampdu tx-only
  aeroscout forward
  antenna-diversity
  airtime-fairness prefer-ht weight 6
Related Commands
no (radio-interface-config-command) Uses single antenna for non-11n transmit rates
