webpage-auto-upload
Enables automatic upload of advanced Web pages to requesting clients on association. Enable this option if the webpage-location is selected as advanced. For more information, see webpage-location.
If this feature is enabled, Access Points shall request for Web pages from the controller during adoption. If the controller has a different set of Web pages, than the ones existing on the Access Points, the controller shall distribute the Web pages uploaded on it to the Access Points.
Syntax
webpage-auto-upload
Parameters
None
nx9500-6C8809(config-captive-portal-test)#webpage-auto-upload
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 webpage-auto-upload
 logout-fqdn logout.testuser.com
Related Commands
no
Disables automatic upload of advanced Web pages on a captive portal
webpage
Configures Web pages displayed when interacting with a captive portal
webpage-location
Specifies the location of the Web pages used for authentication
