next-server (dhcpv4-pool-static-binding)
Configures the next server utilized in the boot process
Syntax
next-server [<IP>|<HOST-ALIAS-NAME>]
Parameters
<IP>|
Configures the next server‘s (the first server in the boot process) IP address
<HOST-ALIAS-NAME>
Configures a host alias, mapped to the next server‘s IP address
  • <HOST-ALIAS-NAME> – Specify the host alias name. It should be existing and configured.
Note: A host alias maps a name to a single network host. For example, ‘alias host $HOST 1.1.1.100‘. In this example the host alias is ‘$HOST‘ and it maps to a single host ‘1.1.1.100‘. For more information, see alias.
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-test)#next-server 172.16.10.24
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-test)#show context
  static-binding client-identifier test
   ip-address 172.16.10.9
   client-name RFID
   domain-name documentation
   netbios-node-type b-node
   bootfile test.txt
   default-router 172.16.10.8 172.16.10.9
   dns-server 172.16.10.7
   netbios-name-server 172.16.10.23
Related Commands
no (dhcpv4-pool-static-binding)
Resets values or disables DHCP pool static binding settings
