crypto-map-ipsec-manual-instance
Defines encryption and authentication keys for this crypto map
session-key [inbound|outbound] ah <256-4294967295> [0|2|authenticator [md5|sha]] <WORD>
session-key [inbound|outbound] esp <256-4294967295> [0|2|cipher [3des|aes|aes-192|aes-256|des|esp-null]] <WORD> authenticator [md5|sha] <WORD>
| session-key [inbound|outbound] | Defines the manual inbound and outbound security association key parameters |
| ah <256-4294967295> | Configures
                        authentication header (AH) as the security protocol for the security
                           session
 The SPI (in combination with the destination IP address and security protocol) identifies the security association.  |
| [0|2|authenticator [md5|sha] <WORD>] | Specifies the
                        key type
| esp <256-4294967295> | Configures
                        Encapsulating Security Payloads (ESP) as the security protocol for the
                        security session. This is the default setting.
| [0|2|cipher [3des|aes|aes-192| aes-256|des| esp-null]] |
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#session-key inbound esp 273 cipher esp-null authenticator sha 58768979 nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context crypto map map1 1 ipsec-manual peer 172.16.10.2 mode transport session-key inbound esp 273 0 cipher esp-null authenticator sha 58768979 nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#
