use
crypto-map-ipsec-manual-instance
Associates an existing IP access list with this crypto map. The ACL protects the VPN traffic.
Syntax
use ip-access-list <IP-ACCESS-LIST-NAME>
Parameters
ip-access-list <IP-ACCESS-LIST-NAME> Specify the IP access list name.
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#use ip-access-list test
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context
 crypto map map1 1 ipsec-manual
  peer 172.16.10.12
  mode transport
  session-key inbound esp 273 0 cipher esp-null authenticator sha 5876897
