crypto-map-ipsec-manual-instance
Uses the configured IP as local tunnel endpoint address, instead of the interface IP (Advanced Configuration)
local-endpoint-ip <IP>
| local-endpoint-ip <IP> | Uses the
                        configured IP as local tunnel‘s endpoint address
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#local-endpoint-ip 172.16.10.3
