Graphing IPv6 VRRP Statistics
Use the following procedure to graph IPv6 VRRPv3 statistics for monitoring the network performance.
- In the navigation pane, expand the Configuration --> IPv6 folders.
- Click VRRP.
- Click the Stats tab.
- Select an interface, and click Graph.
- Select one or more values.
- Select a graph type,
click one of the icons in the upper-left corner of the menu bar. Your
choices are:
- Line Chart
- Area Chart
- Bar Chart
- Pie Chart
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
| Name | Description |
| InetAddrType | Shows the type of IP address (IPv4 or IPv6). |
| ChecksumErrors | Shows the number of VRRP packets received with an invalid VRRP checksum value. |
| VersionErrors | Shows the number of VRRP packets received with an unknown or unsupported version number. |
| VrIdErrors | Shows the number of VRRP packets received with an invalid VrID for this virtual router. |
